Rattles and Crackles.Any solutions?
DC-4 clear Silicone grease works very well, also keeps the rubbers/seals from weather cracking. Apply with brush and whipe of with clean cloth, good for electrical connectors also, protects the pins and mating sockets from corrosion. Robby.mpoufos wrote:Does anyone have any ideas of how to fight those annoying noises coming from the roof while i drive? Do you have any product that you could suggest me ,to use and stop those crackles? Thanks in advance.
Hi LyndonLyndon wrote:if it's the rubber seals then a silicon based spray such as autoglym rubber and vinyl car should sort them out
please do a forum search for more information
Do you want to add my advice to sticky? http://www.peugeot206cc.co.uk/viewtopic.php?id=11432
Kerry
p.s. I have some of the High Vacuum Grease if anyone needs any.
Fear is just a feeling, fear cannot kill you!
Re: Rattles and Crackles.Any solutions?
After having the 206 for a few days i found the catches on mine to be the cause of the rattles . So I've coverd the clasps in a thin edging rubber. Like found on cable trys,,, and so far so good... Rattle free (ish) ,, prob won't last to long in summer when they get opened and closed lots. But in winter they should be fine,, Cheap 2 min fix
The roof doesn't creak on my gf's when it's up, but I've noticed a small creak from my side when it's down. It annoyed me at first, but I quickly ignored it. I'm guessing it's the rubber. I might blast a bit of silicone spray on it though.
