Roof help needed!
steve8621
Post by steve8621 »
Hi All,
I started to notice my roof was starting to struggel when putting up or down.
After taking a look i noticed the fuilded was very low.
Dose anyone know how to top the fuilded up? im not too sure if its
leaking or just needs filling thanks.
mgtf 2 206cc
Post by mgtf 2 206cc »
hello , i posted the same kind of post months back no one helped , i had the same problem , anyway i finally fixed mine sooo happy well my dad fixed it ,
my roof wouldnt open or shut as the hydrillic fuild was too low and was leaking , all he did was went peugeot and brough the oil cost around £11.00 then removed all the casing the the boot , you will see once the casing get removed you have a little box thing on the right hand side undo it and you will see the pot of oil , u have to the metel thing around it or u can get a serfing and it will take ages its up to u , either way it will make the roof work once it has been filled up ..
i no how you feel i was stressing for months now its fixed and works better than before
hope that helps :):):):)
steve8621
Post by steve8621 »
Hey,
Thanks for the reply. All done now, same problem as you was just low.
:D Thanks for you help :D
