My wifes 2002 2.0ltr 206cc has a leak in the roof & i cannot figure out were its getting in, I can see were its coming into the car but have no idea how its getting in, I have adjusted the roof & door so they are tight, adjusted the window so it sits under the rubber & put silicon grease on.all rubber & joints but it still leaks.
The only thing i noticed is that the roof on the passengers seems to sit a little bit tighter than the drivers side it looks like the roof is a little squint with the drivers sticking out a little bit more than the passenger side but im only talking about 1-2 mm of a differance.
Any ideas would be great even if they sound silly as i am at my wits end.
I have added a pic of were the water is sitting, Its not on the rubber that sits over the trim along the roof but above this & it normally sits behind the trim but i have remove it so you can see were the water is sitting, When my wife drives off then brakes she gets a shower which is not very nice when she is setting of for work.
Roof Leaking Surprise Surprise
darkmagi666
gwnricardo
Re: Roof Leaking Surprise Surprise
I havew the exact same problem and it's annoying!! I don't know what to do next:
-New rubbers on the roof side
-Rubbers reseated
-Adjusted the roof and clamps
Does anyone have a solution??
Merci,
Greets!
-Rubbers reseated
Merci,
Greets!
gwnricardo
any one?!
