Hi everyone!!! my pug needs help!!!
mybusa
Post by mybusa »
Hi can anyone help, I have a problem with the engine cutting out when slowing down, but the engine will start after with a little bit of an uneven tick over.
The throttle cable is fine
I have changed the airfilter, oil, oilfilter, spark plugs, coil pack, ECU BSI unit.
Would the crank sensor be at fault.
I have only owned the car for two months and on the second day the ECU cooked!!!
after it seems the coil pack tuck it out with a really big (CATTLE PROD!!!)
CAN ANYONE HELP PLEASE!!!
