Hi my daughter as a 1.6 206cc 53reg and it as started cutting out every so often everything turns of dash lights ,lights its just as if you have turned the ignition off
thank you in advance for any ideas
cutting out
Re: cutting out
Battery?
Battery connections?
Earth lead?
Welcome to the forum.
Earth lead?
Re: cutting out
As above, but also plug an rear of ign switch?? and the 30amp fuse that protects it (MF07)
