computer interface for the 206cc
christine
Post by christine »
Hello again I am concidering buying a computer interface kit on Ebay ebay Item number: 150752809218
I wonder if anyone has had and used one of these and thinks its worth the money.
Many thanks
Colline
Re: computer interface for the 206cc
Save your money. The give away is the bit that says
Full database built-in of generic fault code definitions
It's a glorified EOBD reader. With peugeots (like most others) you quite often need manufacturer specific codes, as well as the ability to read ABS / Airbag faults etc: I would think the £25 ones are nearly as good.
My day-to-day code reader was £3500 and that doesn't do every vehicle fully. I have other kit for Mercedes / VW etc; (Although it's good for Peugeots luckily)
Not trying to be funny, you also need to be able to interpret the results and what they mean. For example, would you know what to do if you got P0220 (Throttle/Pedal Position Sensor/Switch B Circuit Malfunction Track 1) ?
You need to know how to further diagnose that component so you don't end up spending a fortune on parts you don't need (most dealers will not give refunds on electrical parts, unless supplied part is faulty)
