12v power socket
psib3r
12v power socket
Post by psib3r »
Hi, just bought a 2001 206cc (SE) and only noticed when I got home that the cigarette lighter is not working, the interior light and glove box light is fine, I believe they are on the same fuse?
Been checking here and the internet and I find different suggestions for the fuse. I checked under the steering column and I am led to believe it is fuse numbered 22 and meant to be 30A, looked in slot 22 and there is a 10A in there. Could this be the issue? If not and if the unit needs replacing is it an easy job?
suegriff
Re: 12v power socket
Post by suegriff »
I had the same prob, sometimes it will work, sometimes it dont! if look inside the unit sometimes its very full of dirt or the unit totally naffed, i changed mine to 12v power supply unit which is nearly the same unit as a lighter but just a power unit not able to use lighter part.as for changing it over guys on here will advise you. Sue
psib3r
Post by psib3r »
Hi thanks, yes it does look a bit mucky in there, it looks like a hassle to swap over as well.
Well, discovered the issue. Just in case anyone else has the same very simple problem, the fuse list in the manual, bears no resemblence to the actual fuse box, and after investigation, discovered that the fuse F23B a 20A, was missing.
