Windows and Roof Problem
Bakeriell
Post by Bakeriell »
Hello, the back window at the drivers side wont open..is there anyway to open the roof? (not manually)
as i took the car to a local car shop and they managed to open the roof electrically by connecting to a diagnostic tool but i cant open it again once its closed with out using that tool..
Enright
Re: Windows and Roof Problem
Post by Enright »
If it turns out that you need a rear window motor / regulator on the driver's side, I have one.
BCingU,
Neil. ;)
blackpax
Post by blackpax »
You can still open the roof and close it. If you havent solved you problem, since your post is quite old, tell me and I will respond
The OP has posted just the once 2 1/2 years ago and hasn't visited the forum since so don't expect a response anytime soon.
