FAULT CODE P1327 Phase detection intergrated into the igniti
c10ttn
Post by c10ttn »
Hello, since we have had our 206cc 1.6 2004 it has idled rough. After buying it 5 months ago I replaced the spark plugs and put a new coil onto it which did improve its idling alot, but its still a pain to get moving requiring constant adjustment of the pedals due to the revs dropping off. And since the cold weather the car doesn't seem to have any additional fuel going in when cold and will cut out occasionally after being started. The fault code registered is P1327 Phase detection intergration (Peugeot/Citroen being clever), with the computer connected and the engine running at idle the car engine timing was constantly hunting, code was cleared but returned on next engine start. Doing some research the www says it should have a Bourgicord Coil fitted and Bosch Super Plus plugs fitted. Ive got the plugs but where do you get a Bourgicord coil from. Any advice please.
Re: FAULT CODE P1327 Phase detection intergrated into the ig
Website:
http://www.bougicord.com/fr/prod_gen_20 ... 3&id_bob=3
or see
http://car-part-suppliers.mister-auto.c ... cord_e211/
but could find only Sagem or Beru on the latter
or here for more choice
http://www.bestpartstore.co.uk/ignition ... /206-cc-2d
I'd just avoid the Sagem ones.
That code does come up when you get "noisy" ignition. Occasionally the crank trigger will cause it too.
