Clutch fluid leak
IainB
Clutch fluid leak
Post by IainB »
Has anyone had a leak from the clutch slave cylinder?
Got a leak from either the slave cylinder or the pipe going into it. There is a plastic union on the end of the pipe which is a push fit, similar to a compression joint on a plumbing system. Not sure if it is the plastic union or the cylinder.
Any help would be appreciated.
Y Plate 206CC SE
bullitproof
Re: Clutch fluid leak
Post by bullitproof »
clean off the pipe ,any wet area ,get someone to press on the pedal as you look at the pipe to see where its coming from replace as needed :)
IainB
Post by IainB »
Cheers Bullitproof. Will give that a go.
Y Plate 206CC SE
Ours wore through above the gearbox ... Wrongly positioned and not clipped in properly.
And because reservoir feeds both clutch and brakes a big leak isn't fun!!
bullitproof
IainB wrote:Cheers Bullitproof. Will give that a go.
how have you got on mate :)
