Seems to have a slight problem with the drivers door window
When you close it from the inside the top of the glass doesn't seem to seal properly
You lower the window and it 'pops' back in and then you raise the window and alls fine
The difference between the initial non fitting must be very small but you notice the increased wind noise when driving
Does anyone know if this is a common problem as there is no frame to the top of the doors on the cc's?
Kevin
Drivers window glass not sealing on shutting
Re: Drivers window glass not sealing on shutting
Kevin, I suggest you take a look at the following threads. They may be of help to you.
http://www.peugeot206cc.co.uk/viewtopic ... 9&p=125323
http://www.peugeot206cc.co.uk/viewtopic ... 6&p=119340
http://www.peugeot206cc.co.uk/viewtopic.php?f=4&t=14869
Moose
Thanks will take a look now
Moose
Sounds like the window needs moving in a slight bit to allow into the top groove better i'll give it a go and let you know
