Abs
ilo
Abs
I had four different code readers attached to my Peugeot 206 and it shows no faults on the ABS but the light still comes on. sometimes it stays off for a long time once it goes out but when it's on its faintly on and fully on at deferent times would it show on a reader if there was oil or grease on the cogs on the drive shafts thans
Re: Abs
What make were the readers? Did they connect to the ABS system, or just not show any codes?
Dirt, oil & grease shouldn't give any issues. Some ABS systems run inside axles in with the oil.
Slo
Re: Abs
Do you get the abs fault message on the multi display at the same time or ever?
If not and the light comes on faintly it could be just a false alarm and a faulty instrument panel.
Its not a bulb inside its an led and theyre not supposed to light up feint just on or off so something must be dying on your dash somewhere.
Re: Abs
Certainly should have got codes with those machines.
I think Slo may be on the right track. Is there any pattern, ie, it only happens when it rains?
Re: Abs
Brken ring usually give a cohearance fault.
Have you tried live data >wheel speed?
