04 206 cc rear quarter window not quite coming up enough
mark64uk
Post by mark64uk »
Hi can anyone help rear quarter window not quite coming up enough and leaving a gap between drivers window the car is a 206 cc 1.6 on a 04 plate
iooiuk
Re: 04 206 cc rear quarter window not quite coming up enough
Post by iooiuk »
I found that with my rear driver window I have to assist it coming up to ensure it sits in the correct place. Even then I have added some Velcro (soft half). To the rubber seating strip between front and rear to fill the gap.
keithholman
Post by keithholman »
try using slicon grease it cured mine I have the spray type so I also use it on the roof rubbers
Piyas
Post by Piyas »
My 206 cc window also cannot raise all the way up, but going down is fast. What brand can be used, or just any silicon lubricant?
206cc 1.6 16V Petrol
Al4 Transmission
You can find instructions for adjusting the window at http://www.peugeot206cc.co.uk/repair-206/.
Choose Bodywork/Rear Section/Rear Quarter/REMOVAL - REFITTING QUARTER LIGHT - CABRIOLET.
It's basically slackening bolts, holding window in position against the roof, and tightening up, but there is a lot of trim removal to get access.
