hi.sorry for weak english writing
how to do download bsi peuget 206? where is diagnostic socket?
thank you
Bsi Download
Re: Bsi Download
I imagine you mean getting fault codes from the BSI?
The diagnostic socket is on the underside of the fascia (aka dashboard) just above the driver's right leg (on RHD cars, anyway).
Early cars (before some date in 2001, I think) do not comply with EOBD, and you need the Peugeot proprietary tester, which is Peugeot Planet 2000 software and a hardware interface called Lexia 3. Example here. It is also the best tester for later cars
elecspace
Re: Bsi Download
thank you for replay my quesation
Do you for download BSI must be connected to the diagnostic socket ? or bsi socket?
Re: Bsi Download
The diagnostic socket, which is, I think, the large green and black one to the left of the BSI in your photo.
elecspace
Re: Bsi Download
i know. my question : for bsi download , do you must use this socket(green and black) or other socket?
thank you very much.
Re: Bsi Download
Yes. You cannot connect directly to the BSI ..
But you can't download the BSI .. you can alter some settings with PlanetPeugeot2000 though ..
What exactly are you trying to do?
elecspace
Re: Bsi Download
thank you gazza82
i want BSI configrution to do.
result: i must to connect diagnostic socket (green and black) and config bsi ... oky?
Re: Bsi Download
Yes. Do you have Peugeot Planet 2000? If you do not, you will need to get it.
Re: Bsi Download
And the proper lexia3 cable ..IanL wrote:Yes. Do you have Peugeot Planet 2000? If you do not, you will need to get it.
elecspace
Re: Bsi Download
send link " Peugeot Planet 2000" device and lexia3 cable
thank you
thank you
Re: Bsi Download
Link to EBay item.
You will need a PC running Windows XP. If you do not have one, you can use VMWare Player (free) to host a WinXP virtual machine under Win7, 8 or 10.
