My daughter's car was first reg early Jan 2002, but the engine compartment fusebox layout doesn't match the one in the forum download or the Peugeot site, guessing it was an earlier build.
Does anybody have a link to one where this fuse box is bsm b3 please? Wiring diagram would be great also. Looking for abs fuse and wiring info in particular.
Looks like this http://m.ebay.co.uk/itm/Peugeot-206-CC- ... nav=SEARCH
Many thanks in advance
Owner's Handbook - early model
Re: Owner's Handbook - early model
The handbook for your age of car is available at http://public.servicebox.peugeot.com/ddb/. Select language, car and age bracket.
For wiring information there is only one reference of any value. It is a database called the SEDRE, and it has a companion database called the Service Box Documentation, which addresses parts and repair procedures. You can access them online, but many people get thrown off the server, and the procedures are pay-to-view. You can buy the disks on EBay, and struggle with the crack to get it to work, or you can go to http://www.emanualonline.com/Cars/Peugeot.htm and pay a tenner, to have them on your PC permanently. You get the full databases for all the listed vehicles, irrespective of which you click. It is a large download, so if you have slow broadband, you could go for the disk instead. There are no cracks, the system is preinstalled in a VM.
puzzledbloke
Hi and thanks very much for the reply
I did look at the Peugeot handbook site, but they don't give a link for earliest cars -at least that's what i assume the problem is. Earliest one is 01-12-2001, and it shows what i assume is the later unit.
I tried the online manual access a couple of days ago, and as you say got thrown off. Will try again, and have a look at the other site you mention.
Thanks again
Thanks again
The handbook for 1/3/05 to 31/12/05 has two different layouts of the engine compartment fusebox. Hopefully, one is yours.
