Horn Fault
IDH
Horn Fault
Hi, I have a problem with my 2005 206cc, the horn comes on when parked, may-be after 15min or less. I have checked the battery which is fine, had the air bag off and checked the ribbon for shorts, couldn't find any faults, had it on a diagnostics (snap-on) no fault code logged. check fuse box under bonnet and cleaned all dead flies out of fuses and printed board. Has anyone got any ideas please? IDH
Re: Horn Fault
Is this with the roof up or down?
Re: Horn Fault
A couple of possibilities:
http://206infoexchange.proboards.com/thread/1211
https://www.honestjohn.co.uk/forum/post ... tm?t=50415
IDH
Re: Horn Fault
Thanks for getting back, It's with the roof up. I am going to have a look at the door locks to see if any water is in them, will let you know how I get on. IDHGrandadMonkey wrote:Is this with the roof up or down?
