Reset 'STOP' warning light
rogerowen
Just had an issue with a failed thermostat and the 'STOP' light on the dashboard started flashing. Car now fitted with new thermostat and all running good - anyone know how I can reset the 'Stop' warning light, which is still flashing. Disconnect battery maybe? Thanks.
Re: Reset 'STOP' warning light
When the issue has been fixed the light will go off. Check brake fluid level (and sensor) as well as water
Be aware that there is a critical method of disconnecting and reconnecting the battery. See http://www.peugeot206cc.co.uk/viewtopic ... 23&t=13473.
