If anyone gets a reversing kit the ideal place for the camera is beneath the centre of the fog light.
the wiring very straight forward the reverse light wire white is positive.
When you put the wires from the rear to front for the monitor, i found it easier if you put the roof down and cable tie to the black roof wires and remove the passenger side panel, above rear seat belt then you can put the wires under the foot well rubber strip
Just thought it maybe useful if anyone thought of putting rear view camera..
steve
