Engine Management light on after jump start
Nottmtrucker
Post by Nottmtrucker »
Hi guys, appreciate any advice, yesterday jumped started my 206 verve after leaving lights on and flattening battery. Jump started successfully but as l pulled away it went into limp mode. I stopped, switch off ignition for a min or two. Restarted the engine, drives fine but engine management light is now on?
I don't have a code reader, is there anything I can do without taking it to garage?
Re: Engine Management light on after jump start
There is nothing to be done without a code reader, preferably Peugeot Planet.
You may find after several engine start/run cycles, the light will go out. Worth a try.
