Morning all my peugeot 16 00 petrol on a 03plate, I have found out why my ac. Not working
It's the 2 Wires that go in to the ac pump are Corroded that go in to the Grey clip on the pump, Does anyone know if or how replace that part,
Air come pump wiring Crowded
Re: Air come pump wiring Crowded
Try this treatment:https://itstillruns.com/clean-electrica ... 36312.html
If the corrosion is too severe to be addressed by cleaning it off, you will have to replace the corroded part. If it is the harness connector, I suggest you try to get it from a scrapyard, and splice the leads. If it is the connector on the compressor, the parts catalog shows it on a flying lead, so you could possibly do the same, or, failing that, a new compressor clutch unit.
