Hi all, new to forum, thought i would begin by posting an issue which has perplexed me for some time?
Why does the hazard warning switch flash when not in use, no hazards exterior on, flashes all the time, no key in ignition and also when vehicle running?
I assumed was to do with alarm / immobiliser but that doesn't explain being on when driving.
Please note, this is the single switch on older 2001 model not the dual switches with lock icon as seen on later vehicles.
Please enlighten me, forgive the pun!
Hazard Warning Switch Flashing
- Heny
Re: Hazard Warning Switch Flashing
Can anyone help? Really would like to know what flashing means and whether normal to constantly flash?
2001 Y Reg
2.0 Litre
75k + mls
2.0 Litre
75k + mls
Definitely NOT normal.
- Heny
Thanks gazza82; didn't seem right.
Have checked and there is no alarm on this model and it isn't multiplex, so no BSI reset issue?
I'm thinking something to do with door locking as remote key doesn't light up when pressed and obviously doors only lock/unlock with key. Hopefully someone else has seen this issue before and can help further?
Thanks for reply
Thanks for reply
2001 Y Reg
2.0 Litre
75k + mls
2.0 Litre
75k + mls
Just a guess, but I would look for a short between wires in the door harnesses. The weak point is where the harness exits the body and enters the doors.
- Heny
- Heny
No shorts at door, think maybe something to do with MFD as that is all garbled and from what I can see linked to same fuse. Maybe an earth issue or pinouts on ribbon? AC control panel inoperative now too, possibly related?
2001 Y Reg
2.0 Litre
75k + mls
2.0 Litre
75k + mls
