IDing Peugot parts
JohnD
IDing Peugot parts
Post by JohnD »
Hi, I'm NOT a 206 Owner! But I've inherited some Peugeot parts to help me build a kit car, and I need to ID some of them to help me get others.
I'm using a Peugeot 206 GTI torsion bar as a rear antiroll bar. It's 20mm thick. I have the bar lever ends that I've fabricated into adjustable levers for a rear ARB. So far, so good!
Calculations tell me that the second bar will do well for the front ARB (mid-engined car). It is 16mm thick, with splined ends that have 20.5 and 19.3 mm ODs. I don't have any more info on it, not even which model it came from! And I need a pair of bar lever ends, to fabricate my levers as above.
Can anyone tell me which model this second bar is from, please? It would save me a lot of guessing and probably expence if I knew!
Thanks!
JohnD
Re: IDing Peugot parts
Might get answers from this forum too .... they tend to modify/upgrade more ...
http://www.206info.co.uk/Forums.html
Pictures might also help!
Spitfire6
Post by Spitfire6 »
For a Triumph?
Cheers,
Iain.
G6SBH.
