Roof doesn't work. Nothing happened.
Marcin_6
Post by Marcin_6 »
Hello,
yesterday my roof stopped working.
Everything was fine I opened roof and closed it, closed car windows and after this I can't do nothing.
I can't open windows, roof. Nothing beep nothing happened when I click a windows or roof button.
I checked fuses and everything have power. I checked a blind in the back its ok. Earlier when blind is not at micro stick I get beep beep beep but now nothing beep.
Sorry for my language :D.
Please for help.
Greetings :)
Re: Roof doesn't work. Nothing happened.
Did your have the engine running when operating the roof? I always recommend that otherwise there is the danger of flattening the battery.
Marcin_6
Post by Marcin_6 »
Last time not.
But earlier I opened and closed with on engine and off and everything was fine
If it's completely dead, check the plug on the ECU in the boot hasn't come loose
mivu1993
Post by mivu1993 »
Capncol wrote: Thu Mar 04, 2021 8:23 pm If it's completely dead, check the plug on the ECU in the boot hasn't come loose
Having the same problem, fuses are working, buttons as well.
I don't get no errors, no warnings and no beeps.
It's common that the ECU to come loose?
Regards
Just give the plug a good push into the ECU to make sure it's seated properly. It has happened to quite a few.
When ours packed up the roof switch had fried itself.
You have checked the retractable-away cover in the boot too? Sometimes it's the most obvious ... )check also the small micro-switch in the cover catch)
