Roof wiring diagram
mikemclaren
Roof wiring diagram
Post by mikemclaren »
Can anyone share a wiring diagram of the 2006 206cc roof please. I’ve found and downloaded a nice block diagram of the 306 roof but it’s very different. A wiring diagram showing Ecu PIN numbers against the micro switches would be brilliant. Many thanks. :)
Re: Roof wiring diagram
You need the Peugeot Service Box. The online version is pay-to-view, but you can get an installable version from emanuals for £10.99.
The wiring information is in the section called the SEDRE. It is interactive, i.e. when you hover over each microswitch symbol, it pops up the name of the sensor. It shows the wire numbers (Peugeot does not use colours as identifiers) and the Roof ECU pin numbers.
mikemclaren
Hi, good call, now have my diagram. Many thanks. 👍
