Horn Issues
hairdoo
Horn Issues
Post by hairdoo »
Yes i know theres numerous posts about this but i cant find a answer to my issue ,ive a 2005 206cc and the horn no longer works the relay under the fusebox clicks ,also i removed the horn took 2 mins to remove ( i took off the entire bracket for the horn) the horn works fine when hooked up to the battery and finally ive had airbag off the steering wheel and cleaned the black earth terminal ,the one with the little torks screw and the spade terminal with red wire even cleaned the three contacts but still nothing ! So hope you can help as i need my horn...cheer's everyone n stay safe
Re: Horn Issues
If the relay is working, it is possible that the power which the relay switches is not present. Check Fuse 13 (15Amp) in the Engine Compartment Fusebox.
