2.0 16v Accelerator pedal and sensor
Slinky
Post by Slinky »
Can anyone recommend anywhere that might have the above available ?
The part number I'm after is Bosch 0208755080, PSA 9659879580
I've tried a few places and the numbers don't seem to exist, I'm not sure if another part is compatible ?
Will check with Peugeot tomorrow as well.
Re: 2.0 16v Accelerator pedal and sensor
That PSA number is not in the normal range or form.
Assuming the car is RHD, the pedal is:
1601 N1 4 VOIES
- PEDAL STANDARD UNTIL RPO 10800
1601 X6 5 VOIES
- PEDAL STANDARD SINCE RPO 10801
1601 P0 4 VOIES
- PEDAL ALUMINIUM UNTIL RPO 10800
1601 X7 5 VOIES
- PEDAL ALUMINIUM SINCE RPO 10801
I believe VOIES is the number of forward gears.
Slinky
Post by Slinky »
Thank you again for your help :-)
Spoke to Peugeot and they said the numbers aren't showing but have confirmed 1601x7 to be the part but NLS.
Have found some other part numbers on the pedal pa66gf30 and f00c3e2057.
A specialist company that breaks 206's was really helpful and checked for all the parts and nothing found.
Would anyone know if you can use another pedal from the same year but different part numbers ?
Vittorio
Post by Vittorio »
Do you have the details of the specialist company that breaks 206’s please?
