Hi again,
I thought I would try and pick your brains on what could be the problem.
I'll start at the beginning l.
The car is a 2003 petrol 2 ltr 206 cc.
The central locking works perfectly off the key fob.
I lock the car ,but every now again when I go to unlock it with the fob the alarm goes off.
A quick press of the button stops it and the car starts and behaves normally.
It does however only seems to happen when the weather is really cold.
The battery in the car is virtually new and the key fob battery appears to be good too.
Any ideas?
Any comments or suggestions gratefully appreciated.
Kind Regards,
Johnny.
Alarm goes off when I unlock my car
Johnnyb60
Gloria
Re: Alarm goes off when I unlock my car
Low battery can send weak signals, confusing the car. dirty or bad door/hood/trunk sensor, or a sensitive shock sensor, can activate it.
Oyostepper offer a wide range electric motors including stepper motor for sale, linear stepper motor with lead screw, servo motor online with fast worldwide shipping.
Johnnyb60
Hi Gloria,
Thanks for replying and a Merry Christmas to you.
Since my original post the problem seems to of mysteriously disappeared.
It has been a little warmer though, so the next few days will surely test it with the drop in temps.
Thanks for the pointers though.If the issue decides to rear its head again I will check out the things you've suggested
Kind Regards,
Johnny.
Kind Regards,
Johnny.
