Yeap I now have the white thing rolling around in my boot!!
It seems to have fallen off the cord.
what does it do?? and can pug fix it without a prob??
Does this mean I can't put the roof up until its fixed?
Thanks,Jas
White thing in my boot??
Pauline
Ooooh, that white thing is important I think. It's attached to the emergency cord for manual operation of the roof. Not sure if roof will still work without it, it should always be snuggly in place. Pug must be able to refix? Someone more useful wil be able tell you that!
bergen
Nope, its not that important. You can use your roof as always and you can operate the roof manualy if needed. The plastic ting is just the end of the coard you have to pull if you have to operate your roof manualy. Pull the coard and the plastic thing between the hoops and the rear window (dont know the name of it) releases. As you see, you have nothing to worrie about and no need to rush to the dealer to fix it. You can easily tie it on again yourself, dont be afraid to pull the coard if needed.
http://206cc.norge.cc
