Vibe CBR100 Twin - £150
Height: 290mm
Width: 680mm
Top Depth: 285mm
Bottom Depth: 365mm
Driver: 2x BlackAir 10"
RMS Power: 800w
Peak Power: 2400w
Turbo Ports: 2
Characteristics: Loud Hard Bass
Boston Acoustics GT-24 Amp - £250
Product Description:
2-Channel High Current Amplifier
2 Ohm Mono Stable
Advanced cooling allows varied mounting positions
Adjustable feet for varied mounting surfaces
Terminals accept bare heavy-gauge wire
RMS Power Rating:
175 watts x 2 chan. @ 4 ohms
300 watts x 2 chan. @ 2 ohms
600 watts x 1 chan. @ 4 ohms
900 watts x 1 chan. @ 2 ohms
Adjustable input sensitivity: 0.2 - 5 V
Variable High-Pass Crossover: 20 - 350 Hz (12 dB/Oct)
Variable Low-Pass Crossover: 50 - 350 Hz (24 / 12 dB/Oct)
Variable Q Control: 0.7 - 1.2
Power and Safe LEDs
Recessed RCA Inputs allow clearance for tight mounting locations
Dimensions: 18" L x 9" W x 2-1/2" H
Amplifier Specifications:
Number of Channels: 2
RMS Power (4 ohms): 175 watts x 2 chan.
RMS Power (2 ohms): 300 watts x 2 chan.
RMS Power (1 ohm): Not Stable
Bridged RMS Power: 900 watts x 1 chan.
Peak Power Output: 1800 watts approx.
Min. Impedance Unbridged: 2 ohms
Min. Impedance Bridged: 2 ohms
THD @ Rated RMS Power: N/A
Speaker Level Inputs: No
Amp Preamp Outputs: No
Built-in Crossover: HPF(20 - 350 Hz), LPF(50 - 350 Hz)
Bass Boost: N/A
Signal-to-Noise Ratio: >100 dB
Fan Cooled: No
Fuse Rating: 20A x 3
Ground Zero GZRA 4200X Amp - £100
Output power 4 ohms 4 x 85 WRMS / 2 ohms 4 x 125 WRMS
Trimode,
2 ohm stable
Dual mosfet power supply
CH 3&4 =low / band / highpass / subsonic adjustable x-over, bassboost CH 1&2 = high/lowpass adjustable x-over
Pyle Power cap - £50
1 Farad
Red Digital Display
Chrome End Caps
Instant Current
Maximum Bass Performance
Game Cube - £100
4 Joypads, 5 Games & Memory Card (Boxed)
Super Monkey Ball 2
Minority Report
Mat Hoffman's Pro BMX 2
Big Air Free Style
International Superstar Soccer 2
(Sorry no pic can get pic if requested)
