speedo reading slow
patty
Post by patty »
hi all,
been reading through all the old posts ref:speedos
ours now reads 10-20mph slower and seems to take at least 20mph to get going.:(
is this the sensor on the (gearbox) that ive been reading about??
or do you think its a new speedo??needed
thanks in advance
pat.
patty
Post by patty »
well been out today in the car,
and the speedo seems to work ok,but as it now sits on the stop sign in the bottom,it takes at least 20mph just to read 0mph.
any ideas anyone???
thanks in advance
pat
Hi Pat,
I understand that disconnecting the battery for a while (10 minutes or so) then reconnecting will cause the speedo to recalibrate itself. However I have never done this myself so I am not speaking from experience.
If that doesn't work then I would suspect the speed sensor.
If reap comes on he may well be able to advise you better as he has first hand technical knowledge.
patty
Post by patty »
ron,
tried what you said this morning,with no joy.
thanks anyway,
im wondering weather it is this sensor???
as the needle on the speedo is starting from say 6 o'clock on a clock ,thus giveing me the 20-25mph speed difference.(could it actully be the speedo buggered???
anyone??
thanks again in advance
pat.
patty
Post by patty »
just a thought,
if it is this speed sensor???
is this something i could buy and fit myself???
whereabouts is it on the car???
or is it a pug garage job?
cheers
pat.
Speed sensors are normally part of the ABS system as far as I know. Haven't first hand experience of it though myself. I would check with a dealer or indie rather than replacing stuff willy-nilly, which can be expensive guesswork. However I suppose it could be something more basic like the pointer having moved on its spindle.
Sorry the battery disconnection didn't work, but at least that is ruled out now.
reap
Post by reap »
so the speedo works? it just doesnt sit on the zero? sits at six o clock?
sounds like the needles coming off the spindle.happens alot. need to remove speedo,carefuly pull off the clear plastic face.
pull needle off and push it back on so it faces zero.jobs a gooden. 15 mins tops :)
Thanks reap, I knew you'd know.
patty
Post by patty »
thanks you guys!!
reap,
yes it all still works, just sits at 6o'clock rather than zero.
so hopefully your solution will work.
you make it sound so easy.
but no doubt i will bugger it up somewhere along the line.lol
will have a go when i get a spare hr .
any idiot top tips???
thanks again.
pat.
reap
Post by reap »
yup,dont break the plastis transparant plastic as its not sold seperate,and dont get dirty finger prints on the inside.very annoying. keep it clean and take ya time.:)
