hi,
this is my first post so please go easy on me. My girlfriend has just brought a 52 plate 206cc. If we park the car with the roof down and double lock the door, i can lean over the window and pull the button up and open the door. The alarm does sound but i thought that if you double locked it, no one could open the door from the inside.
Im happy if this is standard but just wanted to know if anyone else can do it.
I think its a bit daft if someone could lean over it, open the door and let the hand brake off. The alarm wont put many people off.
Any feedback would be great.
really nice car to drive by the way and fast,
all the best,
stew
Double locking door and alarming the car
slimgym
I've moved onto a 207cc but I recall to deadlock don't you press the lock button twice? It's either twice to deadlock, or twice to lock but not deadlock!
Personally though I think you're mad to leave the roof down and unattend the car, better safe than sorry for the half minute it takes to roof-up and you won't get rubbish chucked in the car!
Dave
hairy26
slimgym
You shouldn't be able to open the door from t he inside if it's deadlocked, correct. The alarm switch on the dash is I recall just to de-activate the ultrasonic part of the alarm so you can set the alarm (roof up) and leave a window slightly open or something.
I just mentioned the double-push because I know on the 207 you have to double push the lock button to set the deadlocks which is crazy - they ought to be on all the time unless you specifically want them offf.
Dave
hairy26
hi dave,
when i get out of the car with the roof down, i press the lock button twice. i can hear it locking twice. if i then lean over the car, i can then pull up the button and the door opens. good thing is that the alarm does go off. just worried as i didnt think the doors would open from inside with it doubled locked. but i dont know anyone else with a 206cc to ask.
hows the 207cc by the way?
stew
stew
slimgym
Have you tried just pushing it once? Just in case it deadlocks on the first push and the second de-activates it?
Yep 207cc is spot on to be honest, I loved the 206cc and the 207cc improves lots of things. I'd fault it on the doors being too long making it hard to get in and out if someone parks too close, and the alloys stick out priod of the rubber so are easier to scratch than on the 206cc. The 1.6 THP is more powerful than the 206cc's 2.0L and with lower emissions which will matter in a few years if road tax goes up as much as the piggies plan to rip us off for!
Dave
