glove box light not working - any ideas?
cheers!
glove box light
Not Well 206cc
Hi the_doc735
First is a silly question
Do you have a light in there?
I ask this question as mine never came with a light in there so I went to my local scrappy and ripped one out of a standard 206 all there is to it is a switch a bulb and a bulb holder.
The connector was placed and fixed behind the glove box held by a clip then one wire went to the bulb then one went to the switch, (a small square on with a bar jetting out which turns on when the lid is opened)then a wire from the switch to the bulb holder, so any of theys may be faulty, or is it the bulb.
hope this helps
steve
hope this helps
steve
the_doc735
I also went to my local scrappy in the end!Not Well 206cc wrote:Hi the_doc735
hope this helps
steve
