electronic window switcher doe not work after roof wend down
verloren
Post by verloren »
Hello! I have a problem now. Recently i bought 206CC 1,6 and my boyfrend was alweys opening and closing the roof. everything went well. Hi is now abroad and I can't normally contact him. I opend my cabrio today myself, everything went well, but when I closed the roof the electronic windows switcher doesnt work. It makes a beeeping signal and doesant work, I tried many times, but it doesant go. So i left my car with opened windows and closed roof. Maybe I do smth wrong, could somebody consult me, please?
When you close the roof it should make a beep before you take you finger off the closing button. Did it do that? Once it has beeped you then close the mechanical latches each side of the front end of the roof to lock it firmly to the windscreen pillars. Did you do that? Once you've done that the window switches should operate. The sequence as shown in your owners manual needs to be followed precisely.
Welcome to the forum.
verloren
Post by verloren »
Thank you! I was very glad to find this forum!
Actually I did everything as you wrote. Well maybe I was just in hurry and nervous, and did smth wrong.I'll try today one more time to do everything by the instruction :)
verloren
Post by verloren »
Hi! it's me again! well I did everithing as it should be, and still the window switches did not operate. Well, I tried several times to open and close the roof and on the 5th time, I guess, windows started to operate. But I'm not sure, whether it will work next time. I think I'll go to the Peugeot center to check, maybe some mechanisms don't work properly, and when the roof is already adjusted they do not give a signal, so thats why window switches do not operate.
It could be a microswitch working intermittently.
