Drivers door window not fitting under roof seal
ottey
Post by ottey »
My problem is exaclty as the title suggests - my drivers door window does not fit under the roof seal when I close the door. When I close the window it fits fine, just under the seal. I can push the glass back into the right place. As I've not had the car long, the garage took it back to adjust the door and it was fine for a week, but now it is back the same. Is it likely to be a door alignment problem or is the glass going up too much. It has been suggested that the window motor should drop the glass on closing the door, to then put it up automatically to fit inside the seal, but I do not have any problem with the passenger side? Any help or advise will be gratefully recieved.
By the way, 2001, 2.0LSE if that makes any difference.
Ottey
Sounds like an alignment issue. I'd take it back and get the garage to do it again, whilst you've still not had it long..
