As the Subject says, everything works fine, roof goes down ok, boot suts, but the whirring of the motor carries on, as if there's a micro switch or anything not telling the system that the boot is shut - doesn't sound like it's locking mind you, any suggestions??? Anyone know where the micro switches I've read so much about are?
Roof goes down and boot shuts but motor still runs on...
52nd of February
Hello RobinC,
When you put the roof back up, did the bootlid lock then? White I don't know too much about the complex roof mechanism, I learnt a little bit from this video - it's instructions on manual operation of the roof, but it shows where various clips are - the small, red "U" shaped clips called the "jumper clips" need to be in place for automatic locking, maybe if you reset them, it may now lock? At 3:06 in the video, it shows where the jumpers are, and at 2:38, it shows how to lock them and what position they should be in.
http://www.youtube.com/watch?v=HV8iPP9SKu4 The title and description are all in Spanish, but I assure you, the video is in English
I'm not sure, just something to try... Hope this helps!
Good luck!
Good luck!
Last edited by 52nd of February on Mon Oct 26, 2009 1:16 am, edited 1 time in total.
