center screen
lammonut
Hi, can anyone tell me how to change the fuel range readout back to miles from metres, it mysteriously changed without me touching it, If you press the buttons at the side of the screen it changes the langauge and temp from farenheit to celcius , clock from 24 to 12 hr but not the fuel range?:/
bull terrier owning nostalgia junkie 66 lambretta owning essex man
Sounds like a software issue on your car.
How did you get on with changing the headlamp bulb by the way?
And has the cold running improved at all?
lammonut
Hi. only seems to do it when its below freezing, Its been ok lately, my wife says the unit of distance changed from miles to km by itself so must be a gremlin, working away at the moment but will put it in for cambelt change and a sort out when i get back,By the way, Thanks for all your help and interest,Cheers:thumbs:
