My wifes CC's front right headlight is not working. Once I fought past the headlight casing cap and the screen washer funnel, I changed the bulb and the new one did not work. Checked and changed the fuse and again, the light does still not come!
Any suggestions as to where else to check or what to do?
front headlight not working, changed bulb and fuse
dantgk1
- craigdmjv
Re: front headlight not working, changed bulb and fuse
is the connector to the bulbs melted a bit as this happened to mine on the drivers side and rother said it was a coomon problem and wired a new one on and its working again now hope this helps
aaronwillis
Mine just died this weekend too
Luckerly was just bulb
- craigdmjv
my bulb went on pass side last wk end but it always seems to e on driver side when i see a pug with the light out lol
