Hi i asked about this ages ago but never got a correct answer.
My problem is i have a 206 made in 2000 and it definately does not have ABS fitted but the warning light stays on how do i right this tiny problem.
Hopefully i will get a reply from some one who knows the answer.
many thanks.
abs warning light
reap
Re: abs warning light
heya.
it maybe the bsi is configured for abs and is looking for it but cant find the abs ecu so putting up a warning light
wrightedwin
Hi all again and i have found the answer to my problem. I thought i would remove the abs warning bulb as it was annoying me more than anything,so after i had stripped the facia from the dash i put my key in to put the ignition lights on. (to find the correct bulb ) I noticed that the bulb was loose. So i turned ignition off reseated the bulb and switched the ignition light on and lo and behold (Abs?) bulb no longer lit up.
The only thing i can think is maybe a short on the bulb.
Now i am happy.Just goes to show some times it is something so simple that you tend to overlook such an easy problem.
