Air vent help.
Nosvartu
Air vent help.
Post by Nosvartu »
Hello. while the inside of my 206 i've come across one of my interior air vents that has been push in an all the splitters seem to flop about. im just wondering if anyone knows how to take the air vents out so i can try fix this issue i can post pictures :D if needed. any help would be appreciated.
Mike
Nosvartu
Re: Air vent help.
Post by Nosvartu »
Problem Solved :D
Thar
Re: Air vent help.
Post by Thar »
Wow...that was quick :rotfl: It's dead easy isn't it, I had the same problem a little while ago.
Image...............
BadCompany1308
Re: Air vent help.
Post by BadCompany1308 »
I have just purchased a Peugeot 206 and although great for the price, I have noticed that all the air vents seem to have been damaged so the flaps that slide from side to side have been pushed out. I think this is the same issue as the OP and since they have said they have fixed it I was hoping you could share the fix.
Thanks for all future help :)
Thar
Re: Air vent help.
Post by Thar »
If I remember correctly, I just removed the vent. They pop out if you prise them gently with a flat screw driver or similar, you can see where they clip in to the fascia the image below. That way you can acces the sliders and clip them back into place.
