Guide to fitting the chrome roll bars/hoops
Thar
Post by Thar »
By request, here is craigdmjv's guide to replace roll bar hoops....
1. put the roof down.
2. undo the two bolts at the bottom of the rear bench, one in each foot well you can them pull the seat free.
3. undo the bolts at the bottom of the rear parts of seats, the seats then push up to release from there mountings.
4. undo the bolts for the roll bars which should now be visible, once undone the hoop should just pull upwards, you may also need to reuse the bolts.
5. do this process in reverse to re-assemble make sure the bolts are tight and that the seats are correctly mounted.
6. put the roof back up slowly, and i repeat slowly to make sure the glass clears the hoops as there are some stories of hoops going through windows.
If you prefer it in pictures...you may have to register. http://www.peugeot-cc.com/forum/index.p ... entry17074
Image...............
craigdmjv
Re: Guide to fitting the chrome roll bars/hoops
Post by craigdmjv »
thanks thar your a star iv also got another small mod
Flower<3
Post by Flower<3 »
Is there any chance of the hoops being set off when your changing them?
Flower<3
What do you mean by "set off"?
Flower<3
Post by Flower<3 »
The hoops (roll bars) are there as a safety mechanism. If the car flips then the roof is down the hoop extend/shoot up to protect the passages as much as possible. :)
Flower<3
Flower<3 wrote:The hoops (roll bars) are there as a safety mechanism. If the car flips then the roof is down the hoop extend/shoot up to protect the passages as much as possible. :)
Not so Flower - you are wrong. They are cosmetic only.
Flower<3
Post by Flower<3 »
Oh! Lol
Flower<3
Don't worry, you're not the first to have thought that. :)
Issac55555
Post by Issac55555 »
Somone can post the picture guid , the link is not working
