Strange noise when clutch is pressed
grbe
Post by grbe »
I hear strange noise when I press clutch in my 206cc 2.0. It's not very loud but it's getting annoying. What is possible reason?
Before couple of weeks spring that is attached to the clutch in cabin broke and I removed it and now I am driving without it. I am not sure is this connected with this strange noise since this noise appeared couple of days ago. Also, where I can buy this spring?
Re: Strange noise when clutch is pressed
If I were you I would replace the spring first and see if the noise then goes away.
A Peugeot main dealer should be able to supply you. That's where I would go if you have no vehicle dismantlers nearby.
Without you describing the noise my guess would be clutch release bearing. Clutch pedal return spring from Peugeot main dealer.
grbe
Post by grbe »
I was in service, according to the symptoms is's probably clutch bearing.
Do you know where I can order some of the parts, like this clutch pedal return. It's not so cheap at the main dealer.
