206 STOP
Re: 206 STOP
What you are experiencing is normal. It proves the lamp is working.
Stop immediately if the STOP sign is flashing when the engine is running. It is linked to the warning light for the engine oil pressure, the coolant temperature and low level gauge, the handbrake, the brake fluid low level, and electronic braking system ABS fault detection system. If the STOP light flashes you are likely to get one of these other warnings up at the same time.
