heater controls
djvoodoo
heater controls
Post by djvoodoo »
Is it possible to change the standard heater controls eg dial 1's to the digital 1's like these?
http://www.ebay.co.uk/itm/peugeot-206cc ... 46012a95fd
andyr
Re: heater controls
Post by andyr »
did you ever find out if this could be done?
id like to swap out mine also...
EdmundIJones
Re: heater controls
Post by EdmundIJones »
It's call the Automatic Air Conditioning module. I have one in my car and assume it's factory fitted. I recently replaced the bulbs in mine but you can find out if you have the wiring block by taking the centre console out... you can probably do it by just removing the radio as well but a little tight. It's just one wire block that plugs into it and has 4 screws holding the module in place.
andyr
Re: heater controls
Post by andyr »
hmm i will have a look, im taking the fascia off anyway as its getting a chrome replacement.
did your car have the automatic heating system already or did you have the manual dial set up?
i was told that you need to replace the whole heating thing, as the replacement has micro switches to control the fan open/close operation.
My car has A/C and apparently this is relevant as it will more than liekly have the automatic air conditioning module in place so is it just a question of swapping out the fascia from the manual dial to the auto?
i think the auto looks much better to be fair, off the top of your head do you know what the bulbs were that you replaced as ive a few that are needing replaced too.
EdmundIJones
Re: heater controls
It came with it when I bought the car.
The bulbs are standard dash bulbs, same as in the clock. It's hard to work out which bulb doesn't work as there are three from memory, so I removed the clock and took the bulbs out of that and then plugged each one in to test it. I then just went along to the local Pug garage and ask them for some, it was £8 for 5 bulbs and three plastic bulb holders (as I dropped one down into the depths.
andyr
Re: heater controls
Post by andyr »
Ideal will get that sorted out then soon, will also have a look at changing heater matrix from manual to automatic
