How to use the lexia-3 V47 for peugeot 307
lilcrowley
Post by lilcrowley »
I buy a lexia-3 V47 Citroen from China.When I go to download software, upgrade, etc. I connected the equipment into the car, but cannot download, also can't operate the ECU. I'm not good at this, so my friend helped me with three days .Although download software to the device,it still not worked. If you need the equipment number, I can send you.Thanks for any help.
One day someone will walk into your life, then you realize love was always worth waiting for.
Re: How to use the lexia-3 V47 for peugeot 307
You can't download the updates when you've installed from the CD/DVD with the kit .. it's a different source and will corrupt the software on the laptop.
Uninstall it completely and reinstall just from the CD/DVD and ignore any requests to update. You might find a more recent update is on the same CD/DVD in the set ... but if it's anything like mine any update will be for the most recent Peugeot's like the 5008.
You might get more info from http://www.peugeotforums.com/forums/ ... which is where I started my search ...
Gassier Gino
Post by Gassier Gino »
As I know, this Lexia-3 can not works for Peugeot 307 .
No Lexia doesn't work with the 307, but Planet Peugeot does (PP2000). AT least my copy has it on the menu as cars it can connect to. It is possible some models aren't covered, later cars should work with a standard EOBD diagnostics as long as you are only reading and resetting error codes. NOTE NOT OBD-II :facepalm: .
You probably have the PP2000 software with your cables. If not you can download it ...
For a lot more info on PP2000 look at the http://www.peugeotforums.com site under Detailing and Gadgets section
http://www.peugeotforums.com/forums/det ... adgets-29/
Tim
Post by Tim »
Bonjour,
lexia-3 est ne pas compatible avec 307.
Vous pouvez essayer cet outil x431.
Bonne journee
Tim, your 5 posts so far have been banal. One more and you risk being banned. Comprenez?
