seat belts and front passenger suspension 206cc
Wanted items, again only LEGAL stuff......
hemz
Post by hemz »
Hi i'm after both front seat belts in working condition.
And my passenger front suspension spring has broken so after the passenger front suspension leg for a quick and easy swap.
All should be compatible with a 2004 1.6 206 cc.
Delivered to london or can collect if not too far off.
thanks
Re: seat belts and front passenger suspension 206cc
There's a breaker specialising in CCs on ebay ... but based in Warrington, so expect to pay for shipment.
I've also used a breakers in Raunds in Northampton when I needed a 206 gearbox.
Otherwise you can try 247spares and websites like that to source the parts for you ...
I'd be worried about swapping out one strut as you don't know the history. You could find it has a problem later or it's worn differently to the other altering the cars handling. You might be better off swapping out both springs for new at the same time.
gazza82 wrote:I'd be worried about swapping out one strut as you don't know the history. You could find it has a problem later or it's worn differently to the other altering the cars handling. You might be better off swapping out both springs for new at the same time.
I Agree.
If you are worried about changing the springs, take the struts off (as you would anyway) and take them to a local garage to change the springs for you. Having the struts off is the biggest part of the job.
Don't be tempted to cut corners and take the springs off yourself unless you have the correct equipment to do so.
