running on 2
kitten
running on 2
only running on 2 cylinders been checked thoroughly and now gone to peugeot for suspected bm34 replacement,has anybody had the same problem and if so what sort of bill should i be expecting
Re: running on 2
Hi Kitten. I find that diagnosis a bit strange. The BM34 is a fuse box and not likely to cause missfire on 2 cylinders. When you say "been checked thoroughly" can you say what was done and what has been checked.
Any fault codes??
Any fault codes??
Re: running on 2
Agree with Capncol .. fuse box sounds odd ...
More like a coil pack issue .... ours failed a few months back. Got a second hand one and straight and simple swap.
