heater blower intermittent fault
cheekee
Post by cheekee »
Hi.
Hope someone can help.
My heater blower stops working. It happens randomly.
Other times it works ok. I have climate control.
Sometimes it will go off and come back on. Other times it doesn't work for a few minutes and then works.
Is this the symptoms of a failing heater blower ?
Re: heater blower intermittent fault
Most likely a loose connection either on the back of the switch or the motor itself.
cheekee
Post by cheekee »
Thanks.
Can I ask what you mean by switch. Do you mean from the climate control panel itself ?
