Newbie from Northumberland
Winka
Post by Winka »
Hi all new to this site buty hope to become a regular ,looking forward to chatting and swapping hints and tips as to how to get around the 206 ive just got for the wife.Regards Winka.
It is better to let people think you are a fool than to open your mouth and remove all doubt.
My toy pajero2.5 exceed
Wifes 206cc
Re: Newbie from Northumberland
Welcome Winka (that doesn't sound right) :rotfl:
Winka
Post by Winka »
Hi and thanks for the welcome aboard !!! and yes its Winka,with an "I" LOL an Army nickname that has stuck ever since ;)
Wifes 206cc
evilpug
Post by evilpug »
what a winka :rotfl: only joking welcome mate
I used to be a banker so people have a laugh at my expense too. Can't understand why...
Welcome to the forum.
Good grief!
At this rate I'll have to explain why I was called bogey for years..............
Winka
Post by Winka »
Well thats all the jokes out of the way ,lol the 206 that I have got the wife has a unusual fault which I hope someone on this site may be able to help with,when you turn the engine off ,i can remove the key shut the door and the engine will then switch off ,ie it runs on for a few seconds before cutting the engine,im thinking timing ? but have been told that it could be the ECU. It also revs a bit fast on starting but then settles after a short while again any help would be great.
Wifes 206cc
Sounds ECU related. You could try a BSI reset here
Winka
Post by Winka »
Thanks for the heads up Capncol i will print this off if thats ok so I have it to hand when I try this as it seems a lot to remember in ones noggin !!probably wont try this till weekend so will let you know how I get on .Regards Trev.
Wifes 206cc
Winka
oil on air filter
Post by Winka »
Hi all before doing the reset that Capncol put up for me I was just having a general look aournd the car and as I have to get a new bit of exhaust pipe and brake pads I thoughtI'd look at the air filter to see if that needed changing and I found it to be covered in oil well not all of it but about a 3rd of it from the left as you look at it .I took the pipe off from the carb and it has a corrugated section in the pipe this was where the oil had settled Ive cleaned it and replaced it but is this normal as this car is a new beast to me to work on thanks in advance for your help.
Wifes 206cc
