Hi there,
I have an '05 206cc.
Had it a few months now and have been told that when I open the doors the window should drop half an inch and then go back up once the door is closed.
Is this true? I know someone with a 307cc and their windows do this.
Cheers,
YP
Window drop on opening door???
shadow
Re: Window drop on opening door???
not a feature on the 206 i'm affraid
- Thar
My 308 does this, frightened the life out of me the first time it did it!
My daughter's 307CC does this. The 206cc does not.
yellowplanet
Cheers guys. I wont make a fool of myself by taking it to a garage to get fixed then! ;-)
gemgem1980
Just read this chain - because the windows don't drop, how can the window go back behind the rubber seal? When I open the door, it's fine.. When I close the door, the window doesn't fit back under the seal unless I manually push it back in. Will this be solved with applying some silicone lubricant??
Sounds like the window guide channel isn't adjusted properly. It's not a straight forward job, so the silicone is probably worth a go
