Abs: scanned ecu had two faults front wheel sensor left and right both sensors changed and driveshafts at same time, fault still remains with flashing abs fault, abs light a stop flashing on dash.
coil, car is misfiring three codes P1336, P1340, P1327, coil pack replaced along with new plugs, better but still misfires now and again but hesitates less now.
any help would be great thanks
Abs and coil fault
Re: Abs and coil fault
Hello Waxhead.
Good you have the codes, but if you tell us year & model we can point you in the right direction.
Those codes aren't the coil or plugs.
waxhead
Year 2002 52plate
206cc 1.6. i have cleaned crank sensor and that has solved misfiring.
the abs i cant crack, all abs/speed sensors have been changed so im guessing its the abs ecu/pump.
but i have heard that it could also be done to the battery, bearing in the mind the battery is new and is fully charged so cant see it being that?
thanks
thanks
What were the exact abs fault codes?
Did you count the reluctor ring teeth on the new drive shafts? Should be 48 teeth.
Is the air gap correct?
